*morphupdatedatabase
Updates morph volume database.
HyperMesh Tcl Modify Command
*morphupdatedatabase ()
This command updates the database for morph volumes based on the current value of the "cubestat" parameter. This command is called when necessary inside other commands and shouldn't need to be called by the user.
None.
