*detachelements
Detaches elements as a unit from the attached structure, using the specified offset value.
*detachelements mark_id offset
HyperMesh Tcl Modify Command
mark_id
The ID of the mark of elements to detach. Valid values are 1 and 2.
offset
The distance by which the elements should be offset from the attached structure.
To detach elements 10 and one layer of adjacent elements from the remainder of the structure:
*createmark elems 1 10
*appendmark elems 1 adjacent
*detachelements 1 0
   # Handle error
