*createcenternode
Creates a node at the center of a circle defined by 3 input nodes.
*createcenternode node_id1 node_id2 node_id3
HyperMesh Tcl Modify Command
- node_id1
 - The ID of the first node defining the circle.
 - node_id2
 - The ID of the second node defining the circle.
 - node_id3
 - The ID of the third node defining the circle.
Examples
*createcenternode 100 200 300Errors
   # Handle error
