*exportuserdefinedshapes
Exports shape design variables, shapes and nodal information in user-defined format for HyperStudy or Templex analysis codes.
*exportuserdefinedshapes header keyword delimiter1 delimiter1_value nodeid_width delimiter2 delimiter2_value x_coord_width x_coord_precision y_coord_width y_coord_precision z_coord_width z_coord_precision delimiter3 delimiter3_value outputfile
HyperMesh Tcl Modify Command
This command exports shape design variables, shapes and nodal information in user-defined format for HyperStudy or Templex analysis codes.
- header
 - Header information for the node block.
 - keyword
 - Keyword for a node.
 - delimiter1
 - The delimiter type between keyword and the node ID. Valid values are:
- Delimiter - Use for delimiters such as slash, comma, etc.
 - Whitespace - Use for spaces.
 - delimeter1_value
 - If deliminter1 is Delimiter, this is the character to use as the delimiter.
 - nodeid_width
 - Width of the node ID field.
 - delimiter2
 - The delimiter type between the node ID and the x-coordinate. Valid values are:
 - delimeter2_value
 - If deliminter2 is Delimiter, this is the character to use as the delimiter.
 - x_coord_width
 - Field width for output of the x-coordinate.
 - x_coord_precision
 - Field precision for output of the x-coordinate.
 - y_coord_width
 - Field width for output of the y-coordinate.
 - y_coord_precision
 - Field precision for output of the y-coordinate.
 - z_coord_width
 - Field width for output of the z-coordinate.
 - z_coord_precision
 - Field precision for output of the z-coordinate.
 - delimiter3
 - The delimiter type between the x-y and y-z coordinates. Valid values are:
 - delimeter3_value
 - If deliminter3 is Delimiter, this is the character to use as the delimiter.
 - outputfile
 - Name of the output file.
COORDINATES
NODE  /     8844, 5.0000000e+001  6.0000000e+001  5.0000000e+001
*exportuserdefinedshapes "COORDINATES"  "NODE " "Delimiter" "/" 9 "Delimiter" "," 15 7 15 7 15 7 "Whitespace" 1 "shape.dat"Errors
   # Handle error
}Version History
10.0
