*CE_ConnectorAreaCreate
Create area connector(s) at the specific location(s) by mark with certain rules.
*CE_ConnectorAreaCreate entities entitymark linkentity linkmark ent_state ce_rules ce_le_rule tol_flag tolerance group param1 param2
HyperMesh Tcl Modify Command
entities
Types that specify location of area connector(s):
Elems
Surfs
entitymark
The mark for elements or surfaces.
linkentity
Type of entity to be added to the area connector as a link:
Surfs
Comps
linkmark
Mark of surfaces or components to add to the area connector as links.
ent_state
Specifies whether geometry or element gets precedence during realization of connector. Currently, only element is supported.
0 - Geometry.
1 - Element.
ce_rules
Rule to specify if and how a link entity is to be added to a connector.
0 - None.
1 - Now.
2 - A fe realize.
ce_le_rule
Rule that specifies how an entity is to be remembered by the connector.
0 - None.
1 - Use ID.
2 - Use name.
tol_flag
Specifies if tolerance value is applicable.
0 - Use default.
1 - Use specified value.
tolerance
Specified to add entities only with in the given tolerance from the specified connector.
group
Specified if do group after creation.
0 - Do not group.
1 - Group.
param1
For future use.
param2
For future use.
Examples
This example creates 2 area connector at elements 1, 2, 3, 6, 7, 8 and add nearest 2 of the four components specified within a tolerance of 1.0, remembers the components by their IDs, and does not group connectors after creation.
*createmark(elems, 1) 1, 2, 3, 6, 7, 8
*createmark(components, 2) 21 23 24 27
*CE_ConnectorAreaCreate(elems, 1, components, 2, 1, 1, 1, 1, 1.0, 0, 0, 0.0)
Each created area connector displays as a plane with cylinders located at the corners, and only the closest two components are added to it. The total number of layers defined at each area connector is 2.
