*xyplotwindow
Sets the minimum and maximum values for the plot window.
*xyplotwindow plotname xmin xmax ymin ymax
HyperMesh Tcl Modify Command
plotname
The name of the plot.
xmin
The minimum value which the window should be set to along the x axis
xmax
The maximum value which the window should be set to along the x axis.
ymin
The minimum value which the window should be set to along the y axis.
ymax
The maximum value which the window should be set to along the y axis
None.
