*sethistorymemorylimit
Sets the maximum amount of memory that history states are allowed to use.
*sethistorymemorylimit memory
HyperMesh Tcl Modify Command
memory
The maximum amount of memory (in MB) that history states are allowed to use.
  • 0 - Disables all history recording, including potential legacy use cases.
  • -1 - Indicates unlimited.
To set the maximum memory 1000 MB:
*sethistorymemorylimit 1000
   # Handle error
Version History
14.0
