*midmesh_inspect_fix_problems
Repairs found problems in the midmesh inspect module.
*midmesh_inspect_fix_problems entity_type mark_id ProblemType=<value> ?<option1>=<value1>? ... ?<optionN>=<valueN>?
HyperMesh Tcl Modify Command
Repairs found problems in the midmesh inspect module. This must be preceded by a call to *midmesh_inspect_init.
entity_type
The type of entity to repair. Valid values are elements and nodes.
mark_id
The ID of the mark of entities to repair. Valid values are 1 and 2.
ProblemType=<value>
The type of problem to repair. Valid values are EdgeOffSolidEdge, ElemCenterOffMid, NodeOffMid, and NodeOffSolidEdge. This is a mandatory option.
SmoothClusters=<value>
Enables (1) or disables (0, default) smoothing after correction.
SmoothMethod=<value>
If SmoothClusters=1, this sets the smoothing method to use. Valid values are Auto, FixShape, FixSize, and QI.
Examples
To detect and correct nodes off mid, delete empty sets, and shut down the inspect module:
*createmark components 1 "shell"
*createmark components 2 "MidmeshEdges" "Mid"
*midmesh_inspect_init SourceEntityType=components SourceMark=1 TargetEntityType=components TargetMark=2 MinNodeOffMidDeviation=0.2
*midmesh_inspect_fix_problems nodes 2 ProblemType=NodeOffMid SmoothClusters=1 SmoothMethod=Auto
*midmesh_inspect_delete_sets 2
*midmesh_inspect_end
   # Handle error
Version History
2021
