*removeincludefromdisplay
Removes the entities contained in the specified include file from the current display.
*removeincludefromdisplay id shortname
HyperMesh Tcl Modify Command
This command un-displays/masks all of the entities in the specified include file from theHyperMesh modeling window.
- id
 - The ID of the include file. An ID of 0 selects the main file. If not specified, should be blank "".
 - shortname
 - The shortname of the include file. This value can be blank when id is specified. If not specified, should be blank "".
To remove the entities in the include with ID 3 from the display:
*removeincludefromdisplay 3 ""
      To remove the entities in the include with shortname elems.fem from the display:
*removeincludefromdisplay "" elems.fem
   # Handle error
