*createlist
Creates an ordered list of entities for use in a subsequent command.
*createlist entity_type list_id ?"by model" <model_name>? entities
HyperMesh Tcl Modify Command
- entity_type
 - Entity type to put on the list. Valid values are elems, laminates, lines, nodes, plies and surfs.
 - list_id
 - The ID of the list to populate. Valid values are 1 and 2.
 - "by model" <model_name>
 - The optional model to create the list from. If not specified, the current model is used.
 - entities
 - The ID of the entities, in the appropriate order.
Examples
*createlist nodes 1 2 10 3
*linecreatefromnodes 1 0 150 5 179*createlist nodes 1 "by model" model-2 2 10 3
set my_list [hm_getlist nodes 1 0 model-2]
*clearlist nodes 1 "by model" model-2Errors
   # Handle error
}Version History
2020 - Added new option "by model".
