*CE_ConnectorGroupCreateAndOrganizeConnectors
Create new connector group(s) and reorganize connector(s) inside them based on criteria given.
*CE_ConnectorGroupCreateAndOrganizeConnectors entity_type criteria delete_cleared_groups organize_all_ces
HyperMesh Tcl Modify Command
- entity_type
 - Must be set to connectorgroups.
 - criteria
 - The criteria used for creating new connector group and reorganizing connector. Valid values are:
 - delete_cleared_groups
 - 0 - Do not delete empty connector gropus
 - organize_all_ces
 - 0 - Reorganize only ungrouped connectors
Examples
To auto reorganize all connectors based on criteria 1 (one connector group per link combination) and delete empty connector groups:
*CE_ConnectorGroupCreateAndOrganizeConnectors CONNECTORGROUPS 1 1 1
      To auto reorganize only ungrouped connectors based on criteria 3 (one connector group per include) and keep empty connector groups:
*CE_ConnectorGroupCreateAndOrganizeConnectors CONNECTORGROUPS 3 0 0
   # Handle error
}Version History
2019
