*CE_FE_RegisterAdvanced
Registers pre-existing FE to multiple connector IDs.
*CE_FE_RegisterAdvanced entity_type integer_array number_of_integers
HyperMesh Tcl Modify Command
Registers pre-existing FE to multiple connector IDs. Successfully registering pre-existing FE forces a connector to its realized state.
To use this command, a connector must be in user control mode. Also, note that a single FE entity can be registered with, at most, a single connector. Any FE registered with a given connector is treated as part of that connector’s realization.
entity_type
The FE type to be registered. Supported types are elements, systems, vectors, loads and equations.
integer_array
The ID of the integer array that contains the input data. The integer array is created using the *createarray command. This should always be set to 1.
The array is a list of the following variables repeated in the following order:
  • connector_id - A single connector ID.
  • testpoint_index - The connector sub-index in which to register this FE. A connector line with a density of three has three sub-indices (0-2), and a connector point only has a single sub-index (0).
  • number_of_ids - The number of FE IDs for a given connector_id.
  • entity_id - The ID of an FE entity (of type entity_type) to be registered with a given connector_id.
number_of_integers
Integer indicating the size (number of integers) in the integer array created using *createarray.
Examples
First, change connector 7 to the user control mode:
*CE_SetSpecificDetailById 7 2 1 0.0
Second, create the necessary arrays:
*createstringarray 3 "systems" "elements" "systems"
*createarray 3 30 2127 31
Third, call the *CE_FE_Register function for connector 7:
*CE_FE_Register 7 0 1 3 1 3
Finally, turn the user control mode off for connector 7 (optional):
*CE_SetSpecificDetailById 7 2 0 0.0
The following process registers elements 100 and 101 with connector 10, and elements 200, 201, and 202 with connector 20.
First, place connectors 10 and 20 in user control mode:
*createmark connectors 1 10 20
*CE_SetSpecificDetail 1 2 1 0
Second, create the necessary array of ints:
*createarray 11 10 0 2 100 101 20 0 3 200 201 202
Third, call *CE_FE_RegisterAdvanced function:
*CE_FE_RegisterAdvanced elements 1 11
Finally, turn off user control mode for connectors 10 and 20 (optional):
*CE_SetSpecificDetail 1 2 0 0
   # Handle error
