*shapevarupdate_xproduct
Updates a shape variable created from the cross product of two other shape variables.
*shapevarupdate_xproduct markid basenode shape variable A shape variable B baseflag directionflag magnitude
HyperMesh Tcl Modify Command
- markid
 - The ID of the mark that contains the shape variable to update.
 - basenode
 - The ID of the node where the base of the result is located after it is updated.
 - shape variable A
 - The ID of the first shape variable in the cross product.
 - shape variable B
 - The ID of the 2nd shape variable in the cross product.
 - baseflag
 - A flag (0,1) to update the base node of the shape variable.
 - directionflag
 - A flag (0,1) to update the direction and magnitude of the shape variable.
 - magnitude
 - Magnitude of vectors.
None.
