*adjustmass
Adjust mass for a selection of components for LS-DYNA.
*adjustmass entity_type mark_id target_mass target_cogx target_cogy target_cogz
HyperMesh Tcl Modify Command
- entity_type
 - Must be set to comps.
 - target_mass
 - The target mass.
 - target_cogx
 - The target COG x location.
 - target_cogy
 - The target COG y location.
 - target_cogz
 - The target COG z location.
Examples
To adjust mass for component 100 to 200 with COG at (1000,1000,1000):
*createmark comps 1 200
*adjustmass comps 1 200 1000 1000 1000
   # Handle error
}Version History
2019
