*hf_ClearFromWorkingSection
Clears the model from the working section and handles, used to edit the binder.
*hf_ClearFromWorkingSection int_flag
HyperMesh Tcl Modify Command
This command clears the model of the working section and handles, used to edit the binder.
- int_flag
 - Dummy flag. Must be set to 0.
*hf_ClearFromWorkingSection 0Version History
10.0
