*lineextendtopoint
Extends the specified line to a point.
*lineextendtopoint line point capture_radius derivative direction
HyperMesh Tcl Modify Command
line
The ID of the line to extend.
point
The ID of the point to which the line is extended.
capture_radius
If the point at the end of the extension is within the capture_radius of the point, then force the end point to have the same coordinates as the point.
derivative
1 - Extend the tangent to the line
2 - Extend following the curvature of the line
direction
1 - Extend the end of the line
-1 - Extend the beginning of the line
None.
