*rigidscombine
Combines rigids and rigidlinks.
*rigidscombine mark combine_common_inode
HyperMesh Tcl Modify Command
- mark
 - The ID of the mark containing the elements to combine.
 - combine_common_inode
 - If combine_common_inode =1, then rigids and rigidlinks that share a common independent node will be combined.
To combine elements 100 and 101 into one rigidlink:
*createmark(elements, 1) 100 101
*rigidscombine(1,1)
None.
