*elementtesttetracollapse
Tests tetra elements for whether or not they pass the tetra collapse element quality check, and puts those that fail on the specified outputmark.
*elementtesttetracollapse entities markmask collapseval outputmark contour title
HyperMesh Tcl Modify Command
- entities
 - The entity types to be checked. Currently, only elements is supported.
 - markmask
 - The mark that contains the elements to test.
 - collapseval
 - The value to use as a threshold beyond which elements should be considered to have failed the test.
 - outputmark
 - The mark where HyperMesh should put the elements that fail the test.
 - contour
 - A code telling if HyperMesh should:
- 0 - Display the results of the test normally.
 - 1 - Display the elements color coded by their ratings.
 - 2 - Build a histogram showing the distribution of ratings.
 - title
 - The title to label the curve in the histogram.
*createmark(elements,1) "displayed"
*createmark(elements,2)
*elementtesttetracollapse(elements,1,0.5,2,0,"Tetra Collapse")
      The details of the tetra collapse element quality check can be found in the online help for the Check Elements panel.
