*show_new_edge_target_by_number
Displays the target for a selected surface edge number in the new target component.
*show_new_edge_target_by_number face e1_edge_number e2_line is_opposite
HyperMesh Tcl Modify Command
- face
 - Index of the surface to be offset.
 - e1_edge_number
 - Number of the surface edge to be offset.
 - e2_line
 - Index of a pilot line.
 - is_opposite
 - 0 - Uses e2_line as the target.
Users cannot manually employ this command, because HyperMesh must internally generate the index values (they cannot simply be typed in).
None.
