*morphdomainsetcolor
Sets the color of a single domain.
*morphdomainsetcolor domain_id color
HyperMesh Tcl Modify Command
This command will set the color of a domain to the specified color.
domain_id
The ID of the domain to update.
color
The color of the domain. Valid values are 1 through 64.
To assign color 45 to domain 33:
*morphdomainsetcolor 33 45
   # Handle error
Version History
12.0.110
