*reviewsystem
Reads and plots the x-axis of the element (material) coordinate system for selected elements.
*reviewsystem markmask onlyorient normal_size color
HyperMesh Tcl Modify Command
markmask
Determines the selected elements.
onlyorient
If onlyorient = 1, the new x-element directions are displayed as vectors starting from the element center.
If onlyorient = 0, the new x-element directions are shown as continuous gradient lines starting and ending on free edges.
normal_size
If onlyorient = 1, it determines the size of the vectors to be displayed.
color
Determines the color of the vector or line. The color ID numbers range from 1 to 64.
To review the element (material) coordinate system of four selected elements and display them as blue vectors (color 7) with size = 3:
*createmark(elements,2) 304 305 316 1841
*reviewsystem(2,1,3,7)
*vectorsoff()
The *createmark() and *vectorsoff() commands are required.
None.
