*modelcheck_loadconfigfile
Loads the default model check config file associated with the current profile and creates check and correction entities.
HyperMesh Tcl Modify Command
Loads the default model check config file associated with the current profile and creates check and correction entities. Any user specified custom config file takes precedence.
None.Examples
To load the default config file:
   # Handle error
}Version History
2019
