*hwct_savetolibrary
Saves representations to a connected library.
*hwct_savetolibrary entity_type mark_id rep_alias_list params
HyperMesh Tcl Modify Command
entity_type
The type of connected library. Currently only supported for subsystems.
mark_id
The ID of the mark of entities. Valid values are 1 and 2.
params
A quoted, comma separated string, containing additional optional name=value parameters. Valid parameters are:
comment=<value>
The comment to add for the action.
overwrite=<value>
0 - Do not overwrite the library information
1 - Overwrite the library information
rep_alias_list
The list of representation alias names to save.
repcomment=<value>
The comment to add to the representation object in the library view.
Examples
Save crash and nvh representations for subsystem 2 with overwrite option:
*createmark subsystems 1 2
*hwct_savetolibrary subsystems 1 "crash;nvh" "overwrite=1"
   # Handle error
Version History
2020
2021.1 – Added repcomment=<value>.
