*ME_ModulePosition
Positions a module using its hierarchical transformation matrices.
*ME_ModulePosition id position reserved
HyperMesh Tcl Modify Command
- id
 - The ID of the module to position.
 - position
 - 0 - Transform to the normal position. This is the position the module will arrive to after applying all necessary hierarchical relative matrices.
 - reserved
 - Reserved for future use. Must be set to 0.
Transform module part 168 back to its original representation file position:
*ME_ModulePosition 168 1 0
   # Handle error
}Version History
14.0
