*memberpanelmesh
Meshes memberpanels to create 2D elements.
*memberpanelmesh mark=<mark_id> elemsize=<value> elmetype=<value>
HyperMesh Tcl Modify Command
Meshes selected member panels to create 2D elements.
mark=<mark_id>
The ID of the mark containing the memberpanels to mesh. Valid values are 1 and 2.
elemsize=<value>
The entity type to be moved. Valid values are memberjoints, members and memberpanels.
elemtype=<value>
The element type used for mapped meshing algorithms. Valid values are:
0 - trias
1 - quads
2 - mixed
3 - right trias
4 - quads only
Examples
To mesh displayed memberpanels:
*createmark memberpanels 1 displayed
*memberpanelmesh mark=1 elemsize=10.0 elemtype=1
   # Handle error
Version History
2022
