*setmarkdisplayattributes
Set the display attributes (wireframe/hidden line, color, etc.) for the entities contained in a mark.
*setmarkdisplayattributes entitytype mark style colortype
HyperMesh Tcl Modify Command
- entitytype
 - The type of entity contained in the mark; limited to "components" and "multibodies".
 - mark
 - ID of the mark whose display attributes you wish to change.
 - style
 - The desired rendering style of the entities:
- 0 wire frame
 - 1 hidden line
 - 2 hidden line with mesh
 - 3 hidden line with features
 - 4 hidden line, transparent
 - colortype
 - Determines how the components are colored.
- 0 none
 - 1 component color
 - 2 assigned plots
 - 3 contours
To change the attributes of a component named "Front Panel" to hidden line using component color
*createmark(components,1) "Front Panel"
*setmarkdisplayattributes(components,1,1,1)
None.
