*addincludetodisplay
Adds the entities contained in the specified include file to the current display.
*addincludetodisplay id shortname
HyperMesh Tcl Modify Command
This command displays/unmasks all of the entities in the specified include file to the HyperMesh modeling window.
id
The ID of the include file. An ID of 0 selects the main file. If not specified, should be blank "".
shortname
The shortname of the include file. This value can be blank when id is specified. If not specified, should be blank "".
Examples
To add the entities in the include with ID 3 to the display:
*addincludetodisplay 3 ""
To add the entities in the include with shortname elems.fem to the display:
*addincludetodisplay "" elems.fem
   # Handle error
