*view
Modifies the current view.
*view view_name
HyperMesh Tcl Modify Command
The rotation angle is defined by *setoption rotation_angle.
view_name
View name string Description
bottom Bottom view
down Rotates rotation_angle degrees down
front Front view
left Rotates rotation_angle degrees to the left
oside Other side view
plan Plan view
rear Rear view
right Rotates rotation_angle degrees to the right
side Side view
up Rotates rotation_angle degrees up
leftside Left side view
rightside Right side view
top Top view
iso1 Isometric view 1
iso2 Isometric view 2
reverse Reverse the current view
ccw Rotates rotation_angle degrees counterclockwise
cw Rotates rotation_angle degrees clockwise
leftsidenofit Left side view without fit
rightsidenofit Right side view without fit
bottomnofit Bottom view without fit
topnofit Top view without fit
rearnofit Rear view without fit
frontnofit Front view without fit
isonofit Isometric view without fit
None.
Version History
2019 - Added new view_name values leftsidenofit, rightsidenofit, bottomnofit, topnofit, rearnofit, frontnofit and isonofit.
