hm_circlezoom
Allows you to select a region to zoom into.
hm_circlezoom
HyperMesh Tcl GUI Command
This command allows you to zoom into the model by drawing a window. When the command is first executed, it waits for the cursor to move into the modeling window. The left mouse button can then be pressed and moved to draw out a window around the region to zoom in on. Moving the mouse outside the modeling window cancels the operation.
hm_circlezoom
None.
