hm_panelnamevalid
Determines if the specified panel name is a valid HyperMesh panel.
hm_panelnamevalid panel_name
HyperMesh Tcl Query Command
This command returns 1 if the specified panel exists and 0 otherwise.
- panel_name
 - The name of the panel to query.
To determine if a panel named "load steps" exists:
hm_panelnamevalid "load steps"
None.
