hm_setpanelheight
Sets the height, in pixels, of the panel area for use with custom Tk panels.
hm_setpanelheight height
HyperMesh Tcl GUI Command
This command sets the height, in pixels, of the panel area. This is useful for creating custom Tk panels that require more space than the default panel area. The minimum size is 140 pixels.
height
The height, in pixels, to set the panel area to. Must be ≥ 140.
To set the panel area to 165 pixels and create a custom Tk frame:
hm_setpanelheight 165
set my_panel [frame .my_panel]
hm_framework addpanel $my_panel "Custom Panel"
::hwt::CanvasButton $my_panel.return \
   [hwt::DluWidth 52] \
   [hwt::DluHeight 14] \
   -text "return" \
   -background red \
   -relief raised \
   -command "hm_exitpanel; hm_setpanelheight 140;"
pack $my_panel.return -side bottom -anchor se
hm_framework drawpanel $my_panel
   # Handle error
Version History
10.0
