hm_plotentity
Plots entity as either a vector or a contour plot.
hm_plotentity hm_plotentity entity_type mark_id dataname=<value> plottype=<value>
HyperMesh Tcl GUI Command
- entity_type
 - The type of entity to plot. Currently only supported for constraints.
 - mark_id
 - The ID of the mark containing the entities to plot. Valid values are 1 and 2.
 - dataname=<value>
 - The data name which is to be extracted and plotted.
 - plottype=<value>
 - 0 - Clear plot
Examples
*createmark constraints 1 all
        hm_plotentity constraints 1 dataname=weights plottype=2Errors
   # Handle error
}Version History
2022
