hm_highlightmark
Control the highlighting of a mark of entities.
hm_highlightmark entity_type mark_id highlight ?panel_sensitive?
HyperMesh Tcl GUI Command
- entity_type
 - The type of entity to control the highlighting for.
 - mark_id
 - The ID of the entity mark. Valid values are 1 and 2.
 - highlight
 - The state of the highlighting. Valid values are:
- l, low or lowlight - set to low (gray) highlighting
 - n, norm or normal - set to normal (no) highlighting
 - h, high or highlight - set to high (white) highlighting
 - panel_sensitive
 - Can be used when multiple panel levels have been pushed,
            either using the shortcut function keys, or the hm_pushpanel command.
            This option determines whether to use the current panel or the
            previous panel for the operation. This option is relevant only
            when the list has been created from a panel entity selector under the above conditions.
            Valid options are:
- 0 - Use the previous panel (default).
 - 1 - Use the current panel.
To display a mark of elements in a low state:
*createmarkpanel elems 1 "Select the elements"
hm_highlightmark elems 1 "low"
   # Handle error
