hm_setcommandposition
Sets the position of the command window.
hm_setcommandposition position
HyperMesh Tcl GUI Command
This command sets the position (top | bottom) of the command window. If the command window is not currently visible, it will not be turned on.
position
The position of the command window. Valid values are top and bottom.
hm_setcommandposition top
   # Handle error
Version History
9.0
2021 - Deprecated in HyperWorks but continues to be supported in HyperWorks Desktop.
