hm_viewright
Rotates the model right about an axis oriented vertically across the screen.
hm_viewright
HyperMesh Tcl GUI Command
This command allows the user to rotate the model right about an axis oriented vertically across the screen. The rotation angle is defined using the *setoption rotation_angle command. The base for rotation is defined using the *rotateabout command.
hm_viewright
None.
