hm_callspecialpanel
Displays the specified special panel.
hm_callspecialpanel panel_name
HyperMesh Tcl GUI Command
This command will display the specified special panel.
- panel_name
 - The name of the special panel. Valid names are:
- card
 - controlcards
 - display
 - global
 - options
 - plotwindow
 - "spherical clipping"
 - trueview
 - vis
To open the Spherical Clipping panel:
hm_callspecialpanel "spherical clipping"
   # Handle error
