hm_getitemnumber
Gets the number of a menu item.
hm_getitemnumber panel_name item_name occurrence
HyperMesh Tcl GUI Command
Gets the number of a menu item. The number can be used in other Tcl commands.
panel_name
The name of the panel where the item resides.
item_name
The name of the menu item as it displays on the menu.
occurrence (optional)
More than one menu item may have the same name on a menu; use occurrence to distinguish between them.
Menu items (such as buttons, radio buttons, etc.) have a name and a number. This function will find the number so it can be used in other Tcl commands
None.
