hm_plotshape
Creates a graphical shape.
hm_plotshape entity_type <select_type>=<selection> shape=<shape> ?<option1>=<value1>? ?<option2>=<value2>? ... ?<optionN>=<valueN>?
HyperMesh Tcl GUI Command
- entity_type
 - The type of entity to create shapes for. Valid values are nodes.
 - <select_type>=<selection>
 - The entity or entities to create shapes for.
 - shape=<shape>
 - The shape to create. Valid values are box, cone, cylinder, ellipsoid, frustum and sphere.
 - height=<value>
 - The height for shape=cone, shape=cylinder and shape=frustum.. Default 1.0.
 - l1=<value>
 - The x-component for shape=box. Default 1.0.
 - l2=<value>
 - The y-component for shape=box. Default 1.0.
 - l3=<value>
 - The z-component for shape=box. Default 1.0.
 - radius=<value> or r1=<value>
 - The radius for shape=cone, shape=cylinder and shape=sphere.. The x-component for shape=ellipsoid. The top radius for shape=frustum. Default 3.0.
 - r2=<value>
 - The y-component for shape=ellipsoid. The bottom radius for shape=frustum. Default 3.0.
 - r3=<value>
 - The z-component for shape=ellipsoid. Default 3.0.
 - color=<color>
 - The color to use for the shape. Valid values are 1-64. If not specified, 1 is used.
 - drawmode=<location>
 - 0 - Wireframe
 - transparency=<value>
 - The transparency of the shape. If not specified, no transparency is used.
 - system=<id>
 - The coordinate system to which the shape must be oriented. Default is global system.
Examples
To create a box shape with dimensions 10x15x20 on nodes 1-100:
*createmark nodes 1 1-100
hm_plotshape nodes mark=1 shape=box l1=10 l2=15 l3=20
      To create a box shape with dimensions 10x15x20 on nodes 1-100 using color 20 and wireframe:
hm_plotshape nodes mark=1 shape=box l1=10 l2=15 l3=20 color=20 drawmode=0
   # Handle error
}Version History
2019.1
