hm_fbdplot
Create FBD panel or bar plots.
hm_fbdplot plot_type entity_type mark_id subcase_ids resultid=<value> ?<option1>=<value1>? ?<option2>=<value2>? ... ?<optionN>=<valueN>?
HyperMesh Tcl Query Command
- plot_type
 - The type of plot to generate:
 - entity_type
 - The type of entity for the plot. For panel plots, this must be panels. For bar plots, this must be freebodysection.
 - mark_id
 - The ID of the mark containing the input panels or freebodysections. Valid values are 1 and 2.
 - subcase_ids
 - The subcase IDs to consider, as a comma separated string with each substring consisting of the result file ID, subcase ID and step ID. For example: {1 1 0, 1 2 0, 2 1 0, 2 1 1}.
 - resultid=<value>
 - The ID of the result entity to use. This is a mandatory option.
 - absolute=<value>
 - 0 - Algebraic envelope plot (default)
 - arrlen=<value>
 - The plot arrow length. Default is 75(%).
 - arroworigin=<value>
 - For bar plots only:
 - colorfx=<value>
 - The bar plot Fx force and panel plot normal load arrow color. Valid values are 1-64.
 - colorfy=<value>
 - The bar plot Fy force and panel plot tangential load arrow color. Valid values are 1-64.
 - colorfz=<value>
 - The bar plot Fz force arrow color. Valid values are 1-64.
 - colormx=<value>
 - The bar plot Mx moment arrow color. Valid values are 1-64.
 - colormy=<value>
 - The bar plot My moment arrow color. Valid values are 1-64.
 - colormz=<value>
 - The bar plot Mz moment arrow color. Valid values are 1-64.
 - declim=<value>
 - The decimal number limit. Default is 2.
 - envelope=<value>
 - 0 - No envelope calculation (default)
 - fx=<value>
 - Display the Fx forces for bar plots:
 - fy=<value>
 - Display the Fy forces for bar plots:
 - fz=<value>
 - Display the Fz forces for bar plots:
 - gpf=<value>
 - For panel plots only:
 - midarrow=<value>
 - minmax=<value>
 - 0 - Min envelope plot (default)
 - mx=<value>
 - Display the Mx moments for bar plots:
 - my=<value>
 - Display the My moments for bar plots:
 - mz=<value>
 - Display the Mz moments for bar plots:
 - normalload=<value>
 - 0 - Do not show normal load (default)
 - onelems=<value>
 - onenodes=<value>
 - plotdir=<value>
 - For bar plots only and normalload=1, the plot direction of the normal load:
 - scientific=<value>
 - 0 - Fixed format text (default)
 - showvalue=<value>
 - 0 - Show value text
 - sizescale=<value>
 - tangentialload=<value>
 - tolerance=<value>
 - The tolerance to limit the values for the plot creation. Default is 0.00001.
 - vecstyle=<value>
Examples
*createmark panels 1 1 2 3
hm_fbdplot panelplot panels 1 {1 1 0, 1 2 0, 2 1 0, 2 1 1} resultid=1 scientific=0 gpf=0 arrlen=75 declim=2 showvalue=1 midarrow=0 tangentialload=1 normalload=1 envelope=0 absolute=1 minmax=1 colorfx=3 colorfy=4hm_fbdplot clearErrors
   # Handle error
}Version History
2020
