*absorbentities
Absorb entities using the tabular segregation interface.
*absorbentities entity_type mark_id value_rule tolerance location_unit_rule topology_rule face_angle edge_angle preserve_flag max_cluster_count
HyperMesh Tcl Modify Command
- entity_type
 - The type of entity to absorb. Currently only supported for loads and constraints.
 - mark_id
 - The ID of the mark containing the entities to absorb. Valid values are 1 and 2.
 - value_rule
 - Specifies whether value-based segregation is desired and, if so, the type of tolerance provided (valid for loads):
 - tolerance
 - The tolerance value when value_rule is non-zero. Valid for loads.
 - location_unit_rule
 - Specifies whether location unit-based segregation is desired and, if so, the type of entities considered (valid for loads):
 - topology_rule
 - Specifies whether topology-based segregation is desired and, if so, the type of topologies considered (valid for loads):
 - face_angle
 - The face angle value when topology_rule specifies the mesh edge option. Valid for loads.
 - edge_angle
 - The edge angle value when topology_rule specifies the mesh edge option. Valid for loads.
 - preseve_parameters
 - 0 - Do not preserve
 - max_cluster_count
 - The maximum number of clusters allowed per entity instance. Valid for loads.
Examples
*createmark loads 1 displayed
*absorbentities loads 1 0 0 0 0 0 0 0 0*createmark constraints 1 all
        *absorbentities constraints 1Errors
   # Handle error
}Version History
2020 2022 - Added support for constraints.
