*elementtestaspect
Tests 2D and 3D elements using the aspect element quality check.
*elementtestaspect entity_type mark_id aspect output_mark_id dimension contour title
HyperMesh Tcl Modify Command
- entity_type
 - The entity types to be checked. Only elements are supported.
 - mark_id
 - The mark ID containing the elements to test. Valid values are 1 and 2.
 - aspect
 - The value to use as a threshold beyond which elements should be considered to have failed the test.
 - dimension
 - The option of whether to measure 2D or 3D elements:
- 2 - Measure 2D elements.
 - 4 - Measure 3D elements.
 - output_mark_id
 - The mark ID where the failed elements will be placed. Valid values are 1 and 2.
 - contour
 - Flag that determines how the results are presented. Valid values are:
- 0 - Display the results of the test normally.
 - 1 - Display the elements color coded by their ratings.
 - 2 - Build a histogram showing the distribution of ratings.
 - title
 - The title to label the curve in the histogram. Only required, if contour is 2.
*createmark elems 1 "displayed"
*elementtestaspect elems 1 5.0 0 4 0 ""*createmark elems 1 "displayed"
*elementtestaspect elems 1 6.0 0 2 0 ""Errors
   # Handle error
