*modelcheck_applyautocorrectiononmark
Runs auto correction on specific entities for a given check, if checks are run.
*modelcheck_applyautocorrectiononmark check_display_name mark_id ?correction_display_name?
HyperMesh Tcl Modify Command
- check_display_name
 - The GUI display name of the check. This is case sensitive.
 - mark_id
 - The ID of the mark of entities for which model checker is to be run. Valid values are 1 and 2.
 - correction_display_name
 - The GUI name of the correction. This is case sensitive.
Examples
To run the "Delete unused materials" auto correction for all "Unused materials":
*createmark mats 1 all
*modelcheck_applyautocorrectiononmark "Unused materials" 1 "Delete unused materials"
   # Handle error
}Version History
2019
