*modent_export
Exports a modular entity and its contents using the currently loaded solver template.
*modent_export entity_type entity_id file_name options
HyperMesh Tcl Modify Command
entity_type
The type of modular entity to export. Currently only supported for subsystems.
entity_id
The ID of the modular entity.
file_name
The full path and file name of the file to export.
options
Optional list of quoted, comma separated option strings.
exporttype=<value>
The type of exported file:
solverdeck - An FE solver
Examples
Export the contents of subsystem 2 into an Ls-Dyna deck named "C:/export/Subsystem2_Crash5mm.k":
*modent_export subsystems 2 "C:/export/Subsystem2_Crash5mm.k"
   # Handle error
Version History
2020
