*createCAERO1
Creates an aero component of type CAERO1.
*createCAERO1 start_id n_span n_chord coordinates mode ?table_id_1? ?table_id_2?
HyperMesh Tcl Modify Command
- start_id
 - The ID from which the component and element numbering will start.
 - n_span
 - The number of spanwise boxes to create.
 - n_chord
 - The number of chordwise boxes to create.
 - coordinates
 - The location of the four corner points. This must be 12 values enclosed in double quotes.
 - mode
 - Flag for create or update of component:
- table_id_1
 - The ID of the AEFACT table containing the 1D array of custom element sizes along the span direction.
- table_id_2
 - The ID of the AEFACT table containing the 1D array of custom biasing sizes along the span direction.
Examples
Create an aero component with ID 910001, with 5 span and 10 chord boxes, and custom biasing defined by tables 31001 and 31002:
*createCAERO1 910001 5 10 "1011.96772 124.925267 172.770859 1030.13113 214.800926 176.849632 882.388330 306.675850 186.826681 835.294585 239.767672 184.962570" 0 31001 31002
   # Handle error
}Version History
2019
2019.1 - Added new optional arguments table_id_1 and table_id_2.
