*segmentsetaddfaces
Adds elements using the face/edge option to a segment set.
*segmentsetaddfaces name elem_mark_id node_mark_id break_angle reverse_normals face_or_edge
HyperMesh Tcl Modify Command
- name
 - The name of the segment set to update.
 - elem_mark_id
 - The ID of the mark containing the elements to add. Valid values are 1 and 2.
 - node_mark_id
 - The ID of the mark containing the nodes that define an edge or a face of an element. Valid values are 1 and 2.
 - break_angle
 - The break angle for finding adjacent elements.
 - reverse_normals
 - Create segment set:
 - face_or_edge
Examples
To add elements 1-100 with faces defined by nodes 1-5 to the segment set "test" with a break_angle of 30.0:
*createmark elems 1 1-100
*createmark nodes 1 1-5
*segmentsetaddfaces "test" 1 1 30.0 0 1
   # Handle error
}Version History
2020
2021 - Added face_or_edge values 10, 11, 20, 21, 30 and 31.
