*setelemparamcolor
Sets the color for a specified element quality parameter for elements violating the threshold.
*setelemparamcolor param_id color
HyperMesh Tcl Modify Command
This command is related to the element quality view mode. It sets the color for a specified element quality parameter for elements violating the threshold.
- param_id
 - Specifies the element quality check parameter ID to update. Valid values are:
- 0 - min size
 - 1 - max size
 - 2 - aspect ratio
 - 3 - warpage
 - 4 - max interior angle quad
 - 5 - min interior angle quad
 - 6 - max interior angle tria
 - 7 - min interior angle tria
 - 8 - skew
 - 9 - Jacobian
 - 10 - chordal deviation
 - 11 - quality index
 - color
 - The color to use. Valid values are 1-64.
To set "aspect ratio" color to brown:
*setelemparamcolor 2 28
   # Handle error
}Version History
12.0.110
