*deletemark
Deletes entities from the database.
*deletemark entity type mark
HyperMesh Tcl Modify Command
- entity type
 - The type of entity contained on the mark.
 - mark
 - The ID of the mark to be deleted.
Examples
*createmark(lines,1) 12 13 14
*deletemark(lines,1)This command cannot be used to delete nodes, unless they are temporary nodes that are not connected to any other HyperMesh entity.
