*configurationsuppressactive
Sets the active state for configurations entity type.
*configurationsuppressactive entity_type entity_id
HyperMesh Tcl Modify Command
Sets the configurations entity with the specified ID to "active" state and sets the other configurations type entities of the model in the session to "inactive" state.
entity_type
The entity type. Valid value is configurations.
entity_id
The ID of the configuration entity.
Examples
*configurationsuppressactive configurations 1
   # Handle error
Version History
2022
