*surfacemarksplitwithsurface
Splits a group of surfaces with another surface.
*surfacemarksplitwithsurface mark surface
HyperMesh Tcl Modify Command
- mark
 - The ID of the mark containing the surfaces to be split.
 - surface
 - The surface used to split the other surfaces.
*createmark(surfaces,1) 10 20
*surfacemarksplitwithsurface(1,5)Errors
None.
