*movecuttingplane
Moves a cutting plane a specified distance.
*movecuttingplane axis distance
HyperMesh Tcl Modify Command
axis
The axis that is normal to the plane. Valid values are:
0 - The plane with x-axis as its normal
1 - The plane with y-axis as its normal
2 - The plane with z-axis as its normal
distance
The distance to move the cutting plane along the plane normal.
To move the cutting plane with y-axis as its normal by a value of 5:
*movecuttingplane 1 5.0
   # Handle error
